mic detection help
Go to solution Solved by fank,
help.... i just need somebody
edit: im a dumb ass, spent hours searching for a solution to find a guy with the same problem. a pc restart is all it takes FYI. seems to be to do with the focusrite drivers
hello
im using at2020 xlr mic plugged into scarlett 2i4 with windows 10
just purchased the mic today
in recording devices i can hear the mic input through monitors when i tick on 'listen to this device' however cant seem to use it in other places
in steam for instance, i can select the 'line in scarlett 2i4' option but it wont detect any sound
could use a hand
cheers
Fractal Design Core 2500 i7 4770k GA-Z87X-UD5H Cooler Master Hyper D92 Kingston HyperX 8GB  Powercolor r9 390 PCS+ Antec HCG-620M
https://linustechtips.com/topic/520064-mic-detection-help/
https://linustechtips.com/topic/520064-mic-detection-help/#findComment-6909520
