I'm looking for a second monitor.
Luigi64128
I'm looking for a second monitor. Currently I'm using the ASUS VG248QE (1080p, 144hz, 1ms, 24 inches) and I'm not sure if I should save money and go for a 60hz panel with higher response time or go all out and get a second ASUS VG248QE. Also if you want you can suggest some 24 inch monitors (1080p) .
I don't see much reason to get another 144hz for a secondary display.
A nice IPS panel would probably be better. http://www.amazon.com/dp/B0148NNKTC/?tag=pcpapi-20
Is it possible that Acer and AOC use the same Panel for that Screen ? If so I have the AOC on and can 100% recommend it
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
It's possible but I wouldn't know for sure.
The second screen will look a lot worse than ur main if it's 60hz
The same can go for TN looking worse than IPS.
From what I've experienced and from other people's reactions, IPS over TN tends to make a bigger difference than 144/120hz over 60hz.
144hz tn and 60hz ips is a good combo, u don't need 2 tn 144hz
