Hi.
My Samsung SyncMaster 940BW only has two display ports, the blue VGA and the white DVI-D dual link.
I have a new build coming up with a GTX 960 Strix but its display ports are Dual Link DVI-I, HDMI 2.0, 3x DisplayPort 1.2
I was wondering if I can use the DVI-D cable for both the DVI-I of the 960 to my DVi-D monitor, or am I supposed to buy an adapter.
https://linustechtips.com/topic/519879-dvi-i-and-dvi-d-problems/
Hi.
DVI-I is a combo port that can be used as either VGA or DVI-D. So yes, it will work with DVI-D cables and devices.
https://linustechtips.com/topic/519879-dvi-i-and-dvi-d-problems/#findComment-6906154
DVI-I ports will accept both DIV-A and DVI-D
To complete both of you:
DVI-I can accept all DVIs. So, DVI-A, DVI-I, and DVI-D.
(And because of this wide arrangement of different cables, and both analog and digital, DVI-I is in my opinion the best type of display port (this is, discarding displayport (itself :P), because that's so expensive, and not that widely used). :)
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/519879-dvi-i-and-dvi-d-problems/#findComment-6906231
