No Signal
Go to solution Solved by jond1122,
bad hdmi cable maybe?
I just built my new pc, but when I plug it into the monitor, it says, "HDMI 1 NO SIGNAL." It worked perfectly when the employees hooked it up into a monitor a microcenter, and the cord works on my other pc, though it also had no signal for the first 5 minutes I booted it. What's wrong here? I plugged the hdmi cable into the graphics card and the mobo, nothing on both.
Core i5 4690k @ 3.8 GHz |  Hyperx Fury 8gb ddr3 1600mhz  |  GIGABYTE Z97-MX Gaming-5  |  Cooler Master Hyper T4  |  XFX R9 390 8gb  |  Corsair CX750M  |  NZXT H440 Black & Blue  |  Samsung 850 EVO 240gb  |  WD BLUE 1TB  |  ASUS VG248QE 144hz & ASUS VX238H
https://linustechtips.com/topic/519776-no-signal/
It works on another pc though :P
https://linustechtips.com/topic/519776-no-signal/#findComment-6904865
oh ok
Huh. It just worked. I'll buy a new hdmi cable, this one is *beep* up.
https://linustechtips.com/topic/519776-no-signal/#findComment-6904892
