Put a fan in your pc thats blowing air in the general direction of your ssd.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/518901-focused-air-cooling/#findComment-6895006
Is the any focused air cooling solutions out there ?
Wanted too take preventive measures to cool m.2 drivers under heavy load scenarios to prevent thermal throttling.
Trying to avoid ghetto setups.
Fans like the Noctua NF-12 (or whatever) or the Silverstone Air penetrators are pretty much designed to focus air in the manner you are looking for. However. A normal fan will do the job, something like a 40mm fan and a bracket made by yourself will do the job.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/518901-focused-air-cooling/#findComment-6895012
I would recommend buying some cheapo aluminum RAM heatsink and using thermal adhesive pads to apply them that would probably ur best bet. is it ghetto, thats ur judgement
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
https://linustechtips.com/topic/518901-focused-air-cooling/#findComment-6895015
Thanks guys the feedback helps, i got all these ideas on my head but always want feedback to refine them.
I've been stuck doing factory work for the last fifteen years and wanted too get back into the swing of things since vaix.net got sold in 2000 and i moved back too tennessee.
https://linustechtips.com/topic/518901-focused-air-cooling/#findComment-6895102
They can get that hot depending on case configuration and load, but i'm thinking investment lifespan and power consumption + throttling as factors.
And just doing something different that's asthetically appealing.
Right now i'm focusing with a ductwork idea in my head using a small blower and pvc and flex connectors like on a aquarium return to channel air.
I tinkered with this on a terarium one time and think it might be a good reaplication especially for work benches.
https://linustechtips.com/topic/518901-focused-air-cooling/#findComment-6895188
