That doesn't really show anything, how about full usage screenshot?
https://linustechtips.com/topic/518790-issue-with-s6-battery/#findComment-6893779
That is the full usage, I havent been on it at all. No screen time
No I mean 100-0 usage. It might be that your battery level just isn't calibrated since you reinstalled so many times.
https://linustechtips.com/topic/518790-issue-with-s6-battery/#findComment-6893823
Oh, so if I use it and drain it to 0% - it will calibrate it?
Likely. Not exactly 0%, that's not healthy. But full use, at least a couple of cycles.
https://linustechtips.com/topic/518790-issue-with-s6-battery/#findComment-6893874
Okay, so what % do you think I should do? I've done 0% a few time before as I was doing a geekbench test the other day, and got 6hrs screen from the test
just use it normally, I charge at 5-10% every other day.
https://linustechtips.com/topic/518790-issue-with-s6-battery/#findComment-6893908
okay, i will install all my apps and use it normally. When you mean a few cycles, does that mean itll take a few days to get back to normal?
I think it already is normal you just can't tell because it shows random shit in your usage chart.
https://linustechtips.com/topic/518790-issue-with-s6-battery/#findComment-6893975
