I've been watching my processor temperature for some time and it seems to get as low as 32*C at about 15% usage and about 43*C when at 100%. Is normal for a Intel Pentium G630 @ 2.7 Ghz?
The intel website says the max temperature for it is 69*C and i don't think that it will ever get close to it unlike my I3 2120 that at 5% usage it gets as low as 45*C if am lucky and at 100% it goes to 70*C
https://linustechtips.com/topic/518729-cpu-temperature-low/
Yeah that's normal... it's a Pentium so it won't produce that much heat  :huh:
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/518729-cpu-temperature-low/#findComment-6893144
So if a pentium runs this low, then it runs cooler that my graphics card when its at 100%
That's... usually the norm? Gpus are usually rated for 3 digit W values, while CPUs are usualy rated for 2 digits only.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/518729-cpu-temperature-low/#findComment-6893203
yeah... it's normal.
mine is like that.
Old Rig
https://linustechtips.com/topic/518729-cpu-temperature-low/#findComment-6893229
It's fine , honestly there is nothing to complain about , as long as temps aren't below ambient , which would mean a faulty sensor on traditional cooling.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/518729-cpu-temperature-low/#findComment-6893242
mine is like that.
oh, also would I have a chance of being able to play fallout 4 at 800x600 or 640x480 at very low on this pc. The graphics card is a Nvidia geforce gt 605 and i have tried to overclock it from 523 Mhz to 800 Mhz but it became unstable and froze my pc within about 30 minutes and it showed artifacts.
https://linustechtips.com/topic/518729-cpu-temperature-low/#findComment-6893266
fallout 4 at that resolution won't look as good and plus that gt 605 is quite old might not handle it... So there is around a 10% chance you will :/
Old Rig
https://linustechtips.com/topic/518729-cpu-temperature-low/#findComment-6893365
