[PC] Battlefront II problems... halp?
Go to solution Solved by JJJaaammmeeesss,
Found this on steam forums:
Originally posted by JovaFett:
Someone posted how to fix it:
Go to
Control panel > hardware and sound > sound > manage audio devices > recording tab > right click an open area under mic and line in > mark a tick next to show disabled devices > right click on the stereo mix icon that appears and click enable
GIve it a shot
Hey there,
So I recently did a fresh install of windows to try and fix some problems I had before...
I used to be able to run this game while I still used the APU and the 13.xx catalyst drivers...
After I switched to the 260x and refreshed the 13.xx catalyst drivers for it, I could still run the game...
After several driver updates, I could no longer run the game...
System specs:
CPU: AMD A8 5600k
GPU: Sapphire R7 260x (the 2x DVI OC version)
Catalyst version: Crimson 15.12
I can guarantee that the components are fine as I can run other games (Battlefield 3, Metro 2033, Sniper Elite V2, etc.)...
I'm currently suspecting the drivers but would not roll back for just this game... (I'd lose VSR support among a few other things)
oh and Disney Interactive support (yes, this thing is under Disney Interactive now...) is of no help...
https://linustechtips.com/topic/518649-pc-battlefront-ii-problems-halp/
Windows 10?
I forgot to mention... I'm on 8.1 right now... and I don't want to run Windows 10 on my desktop yet...
So what do you mean you can't run the game? Does it launch at all? Does it crash at the menu or when it loads into the game?
01000100 01100001 01110010 01110101 01100100 01100101 00100000 00101101 00100000 01010011 01100001 01101110 01100100 01110011 01110100 01101111 01110010 01101101
I get into the menu and when I start the game it crashes...
I get a similar issue with Need For Speed Underground 2... I can play in the open world mode but once I try to start a race, it crashes...
Edit:
I got the game via steam and have disabled the in-game overlay...
Go to
GIve it a shot
Go to
GIve it a shot
Will try...
Re-downloading the game later tonight (2.5GB on a 5Mbps line... dis gon git gud...)...
Will try...
Let me know how it goes
Holy f*cking sh*t... it works...
Now I have graphical glitches... but at least I can get in the game now...
Going to test a bunch of other non-functioning games that I have...
Now I have a graphical glitches... but at least I can get in the game now...
Hahaha thats good to hear. When i looked at the solution it seemed so weird and unrelated to the problem. Hope all goes well
