Need help.
Go to solution Solved by Guest,
Hey I wanted to ask is 1066mhz DDR3 memory is the maximum that I could put into this board or can I for example put 1333mhz and it would run just fine uderclocking it self or I would need to do that manualy? link to the motherboard http://www.gigabyte.com/products/product-page.aspx?pid=3248#sp
I'm 99% certain that your 1333 memory will downclock to 1066 and run. The 1% is an off-chance that something goes wrong. I've run 800 in a 533 and 1600 in a 1066 - and it ran perfectly fine ;)
https://linustechtips.com/topic/518089-need-help/
https://linustechtips.com/topic/518089-need-help/#findComment-6886386
