HDMI Problems
Solved by W-L,
I can't seem to fit a HDMI cable into the top port on my mother board. It has two and the bottom HDMI port fits just fine. Can anyone help? Did I put the mobo in wrong or did I bend it? I attached a photo. It seems to me that the designs on both are different? Thanks for any help.
It looks like you will need to remount the motherboard, the tab on the IO plate seems to have slipped down into the connector when during install.
