basically, i really want to know youre full config cause that is crazy.  how  far is it all overclocked?CPU:
CPU: AMD FX-8320 @ 3.5Ghz (no turbo. I forgot to turn that on). || Cooling: Raijitek Triton @ 36.3 Degrees MAX  || GPU: MSI Radoen R9 270X HAWK @ 1202Mhz Core and 1450Mhz VRAM with +5 power limit. (58.0 Degrees MAX with custom fan controller) || Motherboard: MSI 970 Gaming || RAM: 2x4GB G-Skill ARES 2133Mhz || PSU: EVGA Supernova NEX650G || SSD: PNY 120Gb || Fans: 2x 120mm Antec controllable fans, 1x fan from an old computer zip tied to my case, 1x 120mm Antec blue LED fan || Case: Thermaltake Commander MS-I that will be replaced by a H440 soon
Also im getting 111464 ppd now
Breaking things 1 day at a time
https://linustechtips.com/topic/517128-work-unit-questions/#findComment-6879107
damn son
all i can say is make sure the h440 doesnt get as ghetto as that is
but thats crazy impressive performance
https://linustechtips.com/topic/517128-work-unit-questions/#findComment-6880503
293194 PPD right now. lol it was only at 80000ish last ight
You might be doing work units that are low in steps. If you can complete low step WUs in rapid succession then you'll get more points.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/517128-work-unit-questions/#findComment-6919276
Can I see some screenshots of your settings etc as I normally get above that with my 970 folding alone?
Chernobyl
Kraken
https://linustechtips.com/topic/517128-work-unit-questions/#findComment-6919343
also a 970 is a WWWAAAAYYYYYYY more powerful card than my 270X
No your setting in F@H, and I know that's why I'm wondering what Voodoo you've done to get such high PPD lol.
Chernobyl
Kraken
https://linustechtips.com/topic/517128-work-unit-questions/#findComment-6919474
