I have been looking for an external fan controller but they only one I keep finding is the nzxt sentry lxe. My pic case is the s340 and there are no optical bays. I was just wondering if there are any other controllers because the nzxt one is 60ish quid.
Those units from NZXT are probably your best bet, other than that if you have an ROG board they do have an OC panel that you can have on the desk which does show fan controls among other overclocking features.
https://linustechtips.com/topic/516971-external-fan-controller/#findComment-6873087
External fan controlers have fallen out of popularity, so there aren't as many on the market anymore... But almost all of them will require an open drive bay of some kind...
Cheap Kingwin Controller
You could try this instead. (Software based solution)
~Cynical~
https://linustechtips.com/topic/516971-external-fan-controller/#findComment-6873089
It's a great piece of hardware, it's just sad that the software used to control it is rubbish.
Corsari Link problem again I assume, I've always wondered since I've never really got to use Corsair link what's so bad with it other than just not working or installing for some.
https://linustechtips.com/topic/516971-external-fan-controller/#findComment-6873368
