Hey People,
I recently posted that I am building a Gaming PC (which indeed I still am) and I got lots of great responses, but I am still torn on one thing, the GPU.
I have done some research and people say R9 390 or Geforce GTX 970, I am willing to spend around $500 Australian dollars on the GPU.
Please give feedback all will be appreciated!
Cheers  :D
https://linustechtips.com/topic/516376-need-help-choosing-gpu/
Hey People,
Cheers  :D
Only way you'd need a GTX 970 is if you're doing CUDA work.  Otherwise, R9 390.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866686
Do you know what brand to get there have been very mixed reviews by users and it is very confusing!
For the 390:
-Any brand will do well except for ASUS and GIGABYTE, which have pretty bad coolers.
-Powercolor is good for someone on a tight budget.
-MSI and Sapphire have the best cards.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866792
I've been thinking of going for the MSI Radeon R9 390 Gaming 8GB Video Card or Sapphire Radeon R9 390 Tri-X Nitro 8GB Video Card but i guess it just comes down to personal preference.
DO whichever one is cheaper. I got the MSI one and think that it's great!
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866823
For the 390:
I've seen that on Mwave the PowerColor cost the same amount of money as the other two so I thought I may as well have gone with them, not sure which one though. Thanks again!
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866827
The Sapphire Tri-X Nitro is the one I'd personally prefer. Great build quality, excellent aftermarket cooler (if not the best) and overall good customer service.
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866867
For the 390:
I have two other things I have wondered:
-Do AMD GPUs work with Intel CPUs?
-Do I need to buy a wireless network adapter for my pc.
They are probably basic questions but if you know the answers it would be greatly appreciated! Thanks
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866876
I've heard it is a GIANT and you have to take out HDD slots to fit it in, is that true?
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866886
Yes, you may have to. But it's only a problem if you have something like 5 HDDs.
Intel CPUs will work perfectly with AMD cards.
https://linustechtips.com/topic/516376-need-help-choosing-gpu/#findComment-6866920
