I'm trying to install Ubuntu and the hard drive I'm installing it on is clicking and beeping. It didn't do this earlier, and now it is. I never dropped it or anything. What's wrong and how do I fix it?
is it a minor or loud clicking and is it more of a scratching sound?
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/516367-hard-drive-issues/#findComment-6866539
if its clicking, then if there's any data on it, get it off, then try and troubleshoot.
I would back everything up... However.... spinning hard drives do make some noises like he described...
The pin has to make contact with the spinning platter disk on the inside so it will make a minute clicking sound..... beeping wise... is it electronic or mechanical beeping?
https://linustechtips.com/topic/516367-hard-drive-issues/#findComment-6866549
It's like a system speaker beeping. Except coming from the hard drive (there's no speaker plugged into my computer)
Breaking things 1 day at a time
https://linustechtips.com/topic/516367-hard-drive-issues/#findComment-6866560
when exactly and how many times does it beep... may be another unrelated problem...
https://linustechtips.com/topic/516367-hard-drive-issues/#findComment-6866576
I'm using another power supply and an identical drive to compare. The good drive makes a loud (when you put your ear to it) noise when it starts. The other one does the same. The difference being you can hear the arm hitting something
https://linustechtips.com/topic/516367-hard-drive-issues/#findComment-6866777
~snip~
Hey there :)
HDDs are mechanical units and do have moving parts. It is normal to to hear a small clicking noise as the actuator hovers over the platter in order to read/write data to it.
If you have trouble recognizing the drive anywhere I would first try another SATA cable on another SATA port and see if that changes anything. I would also try the drive on another system (internally or externally). Booting from Linux Live CD might help in recognizing the drive.
If you manage to recognize the drive the first thing you should do is backing up your data as any troubleshooting might further damage the drive and cause permanent data loss.
I'd check the S.M.A.R.T status of the drive and see what the raw values would tell you. If you are not sure how to read them feel free to post them here and we will help you out. :)
Post back with some results!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/516367-hard-drive-issues/#findComment-6867984
