Lets just start this off by letting you know that I'm apart of the PC Master Race. I just bot an Xbox a while (long time) ago. Whenever i try to start minecraft (from a disk) it freezes after a few seconds. How do I fix this? Do i need to take apart and clean my Xbox? (Warranty is long gone)
Breaking things 1 day at a time
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/
You got the problem of "Xbox disease". I used to have it until I realized i didn't need it..
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6865750
Stop being a retard...
@OP, it might just be loading a bunch of shit, and (being an older console), it might just be pushing the hardware to its limits.
Just to be clear though... When you say freeze after a bit... Do you mean like it works and then freezes up entirely, or freezes and then works?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6865778
like freezes and doesn't unfreeze
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6865793
I rarely play it. Just trying to get it fixed before my sister owes me the $250 for a new one even though id go for a PS4 so i can play with my non-PC friends
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6865799
It could be a dirty disk or a fudged install.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6865806
@TubsAlwaysWIns How did it go?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6868981
Better than before. Thanks
No problemo.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/516290-xbox-360-minecraft-help/#findComment-6870906
