So I am gathering a parts list from a few places around the web plus what some people have that they rate very good for first time loop. The examples I like the best are hard tubing, cylinder res, and one 240 then a 360 for my SLi 970 since they won't sell lol
My budget starts with Newegg since I have 200 in gift cards there. So I am thinking about a starter kit that has the pump and parts then adding a think 360 rad then hard tubing and the reservoir.
Is the Alphacool 240 kit a good start?
http://www.newegg.com/Product/Product.aspx?Item=9SIA9F93HE4420&cm_re=alphacool-_-9SIA9F93HE4420-_-Product
Or search for another starter like kit then add extras? Build is being planned and won't get done till March April around with tax return
i7 4790k
Strix 970 SLi
760 PSU
https://linustechtips.com/topic/516215-mapping-out-water-loop-kit-plus-extras/
If you're going to be using Hard ling then those fittings are of no use in that kit
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
-SNIP-
Personally I would recommend the EKWB kits over those due to the bay res and the DC-LT pumps not being the most amazing out there. Also if you want hardline your going to have to get all new fittings.
thank you and thank you. did not know they are not universal. is ther anythign by Alphacool / off New egg I can grab? EKWB makes the water blocks and back plates I need. The Monsta 360 Rad got decent reviews
http://www.newegg.com/Product/Product.aspx?Item=9SIA9F93EC8692&cm_re=alphacool-_-9SIA9F93EC8692-_-Product
What case do you have cause the monsta rad is a 80mm thick rad without fans yet, if you can however fit long rads than thicker rads those do tend to perform better. As for other things they do have D5 pumps and reservoirs which you can get.
Fractal Define S
keep in mind that if you're using multiple rads the cost of fittings will rise quickly, I found this out recently and am finding out again lol switching to rigid tubing
Ryzen Ram Guide
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=alphacool&page=1&bop=And&SrchInDesc=pump&PageSize=90
the D 5 comes in pieces?
There is also pump/res combos available from EKWB
https://shop.ekwb.com/ek-xres-140-ddc-3-2-pwm-elite-incl-pump
Ryzen Ram Guide
right but I want to burn my 200 gift cards first on newegg :D
For example if you got a or thinner 360mm 420mm rad in the top and a 280mm in the front that would give more than adequate amount of cooling:
thank you for this. Plus i need a new keyboard now cause I spilled semen at teh Iced Blood thread everywhere
lmao
Ryzen Ram Guide
i7 4790k
Strix 970 SLi
760 PSU
pls don't go with this kind of res/pump combo,
in my experience the DCLT pumps are trash, they're loud plus this combo it's hard to get the air out of the res it's just a mess.
you better of saving a bit more money on a good kit.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
no worries, not gonna do it. at first I was thinking get a cheap kit and learn how custom loops work and bleed etc with spare PC parts I have laying around.
then I studied this. I have 90% of the hardware Bill uses and I LOVE the clean look and space there is left in the case.
