Terve!
I am planing on my first dedicated NAS/Server rig. I'd like to know 2 things:
1: Will the parts work together? I am mostly concened about the correct ECC RAM for ZFS.
2: Can this run a 6TB (3 x 3TB HDD) ZFS RAID Z1 (like a RAID 5)?
To 1:
CPU: Intel Xeon E3-1225 V3
Mainboard: MSI H97 Gaming 3
RAM: Kingston Value ECC RAM (KVR1333D3E9SK2/16G)
Will the H97 mainboard szupport ECC and work with the RAM?
To 2:
I know that you say 8GB + Stoarage in TB times 1.5, which would be: 8+1.5*6=17GB of RAM.
This is barely enough and I'd like to be safe.
Thank you already.
Sayonara!
https://linustechtips.com/topic/516068-first-nasserver-build/
Here is a list of LGA1150 boards that support ECC: https://pcpartpicker.com/parts/motherboard/#s=24&A=1
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/516068-first-nasserver-build/#findComment-6863411
Terve!
So if I was to pick the Supermicro X10-SLL-F-O (http://www.amazon.com/dp/B00D65V9WO/?tag=pcpapi-20)
Would the RAM be compatible?
I have had RAM that was not working on certain mainboards in the past and I'd like to avoid that.
The problem is that there is no mobo list for this ram to be found.
Thank you for the list.
Sayonara!
https://linustechtips.com/topic/516068-first-nasserver-build/#findComment-6863528
