CPU fan isnt changing speed
Go to solution Solved by ★ Coups ★,
Its all sorted now. My ears have adjusted to the extremely low noise levels and I can hear the changes ever so slightly. I came from AMD.
Thanks
When I'm in a game I see that the CPU temperature is getting high, but the CPU fan isnt increasing speed or even decreasing speed. Im afraid that something will die. I have the MSI Z97M Gaming Motherboard and a i7-4790k.
I dont understand this. The fan speed thing is in CPUFAN1 header but it isnt doing anything.
I dont want to damage any components and it is getting up to 70c. I turned the game off to protect it as I didnt hear any fans changing. I cannot do it manually because I dont know what my system fans are on speedfan.
Please help, and dont just leave me without an answer, follow the post!
Thanks!
post-237087-0-30941000-1451423180_thumb.
post-237087-0-53705700-1451423205_thumb.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/516050-cpu-fan-isnt-changing-speed/
70c isn't even a dangerous temp at all.
But yeah, you could adjust your fan curve.
Instead of using SpeedFan, go into the BIOS and configure the fan curve manually.
BIOS is a scary place. I added pictures too, can u see if its in the correct CPU fan controller? Theres two on my board.
The temperature got up to 80c sorry
Thats right. BIOS isn't that scary. MSI makes very easy to use BIOS'. The fan curve/speed should be on the main page.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
Howcome the fan has no change at all? Surely it would begin to change after it gets to 80c?!
Try to go inside the bios. It's not a scary place, you won't accidently blow up your pc.
AMD FX8350 Black OC 4.5ghz--NZXT Kraken X31--ASUS M5A99FX PRO R2.0--MSI R9 380 4G--Corsair RM750--Corsair 16GB Vengeance
Logitech G300--Roccat ISKU FX--Logitech Z623--HyperX Cloud II
Alright, will do. If I dont return tell my parents I love them.
Cheers.
Could be speedfan. Ive had it mess up my CPU fan before.
Alright, I'll uninstall that. I've also taken a picture of BIOS fan monitor thing. Hopefully you can understand it!
post-237087-0-39422100-1451424660_thumb.
You're fine up to 80-90c at load.
But the fan doesnt change speed to lower the temps.
And now i'm stuck without an answer, yet again.
Were you using SpeedFan?
Have some patience. It's a forum--not a live chat.
Were you using SpeedFan?Have some patience. It's a forum--not a live chat.
Yes I was using speedfan, I've uninstalled it now but no difference.
Were the motherboard settings reverted to default?
It sa
it said so when I first installed the mobo I think.
It sait said so when I first installed the mobo I think.
You can go into the motherboard's settings and reset them to default just to make sure.
Reset the fan curve? It never exeeds 80c so far thoagh, I dont know much about this cpu. (Long story)
Reset all of the motherboard settings--it's in the menu.
Set it to 50% all the way across the curves in the bios and then set it to 100% and tell us if you can hear any difference and if the bios tells you the the fan speed (rpm) has changed.
Some fans you may not hear a difference or the motherboard/fan may not be able to adjust the speed
Edit: does your fan actually spin up to 7000 rpm? Seems a bit high to me
The stock cooler's fan speed is 800-2500rpm.
  • 2 weeks later...
Thanks
