Build: http://pcpartpicker.com/p/k79DLk
OS: Windows 10 64 bit
I build this computer around 3 weeks ago and ever since I built it i have had this issue.
When I update my windows/Other programs my Ethernet drivers stop working I have to reinstall the drivers every time I update my computer. It says my drivers are still there but in my device manger it has a caution over it (Intel® ethernet connection (2) 1219-v) and my internet stops working. I am plugged straight in to my router with a cord.
Any help would be appreciated thanks.
https://linustechtips.com/topic/516031-internet-problems/
It may be a flaky network controller and needs to be replaced.
Before doing that, you used the Win10 x64 LAN driver (http://dlcdnet.asus.com/pub/ASUS/lan/Intel_Gigabit_Ethernet_Win7-81_V20230010_Win10_V20240010.zip) and updated the BIOS and all other drivers installed properly?
When the issue does happen, check what message you get on the ethernet controller as it will give clue on what kind of error it is. It will look like this:
https://linustechtips.com/topic/516031-internet-problems/#findComment-6880009
  • 2 months later...
