Hey Guys,
I want to start recording my CS:GO gameplay for my friend and I am wandering if I can use my 290x as my main card and a HD 7770 as a recording only card, and if that is possible how can I do it, Thanks
​Nothing Screams Professional Other Than Comic Sans
My Build: http://pcpartpicker.com/p/bQVfqs
Dark Theme, GG
https://linustechtips.com/topic/515995-2-gpu-help/
just use the 290X? I mean, you CANNOT max a 290X via CS:GO since the CPU will be a bottleneck. Using the 290X will make no difference than having a separate card for it
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862488
What do you mean with recording? Using a recording software like fraps or recording with hardware cards?
AMD FX8350 Black OC 4.5ghz--NZXT Kraken X31--ASUS M5A99FX PRO R2.0--MSI R9 380 4G--Corsair RM750--Corsair 16GB Vengeance
Logitech G300--Roccat ISKU FX--Logitech Z623--HyperX Cloud II
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862498
I need at least 300fps, it sounds stupid but even 1000 fps is better than 700 in cs, a little, but still makes a difference
Dark Theme, GG
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862506
I don't think thats how it works. You can only see hoe many FPS put out buy your monitor wichh
research it, I understand in other games, I cap them to 144hz if I can
Dark Theme, GG
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862540
No it does NOT. You can't see more than 60 FPS if your monitor is 60Hz.
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862555
Have fun with those frames rates with your cpu.
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862599
My 860M gets 200fps. A 290X should be getting around 500 easily
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862610
He's right
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862612
RESEARCH IT DAMNIT
and its 144hz, follow the topic
144Hz, same thing, it does not change if you have more FPS than  your monitor can display FFS.
Tablet: iPad Mini 2
https://linustechtips.com/topic/515995-2-gpu-help/#findComment-6862746
