Physical volume knob?
Hello, I'm looking for a physical knob to change the volume on my pc. Is there such a thing?
I'm not looking for a DAC, just a knob that changes the volume.
das keyboard???
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6859252
I'm not aware of an audio interface that integrates itself into a computer and is complete with I/O controls - if it existed, I'm certain I'd already have one.
However, your best bet is to either buy a pair of headphones with a volume knob attached or a volume wheel adapter for your headphones- both of which can be acquired very easily.
Here's a link to two such adapters.
A high-quality one from Shure-
http://www.amazon.com/Shure-EAADPT-KIT-Adapter-Combines-Attachable/dp/B001P5HL3S/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1451384261&sr=1-1&keywords=headphone+volume
And a cheaper adapter from 'Foxnovo' (generic)
http://www.amazon.com/Foxnovo%C2%AE1M-Female-Headphone-Extension-Control/dp/B00DYP98LU/ref=sr_1_2?s=musical-instruments&ie=UTF8&qid=1451384261&sr=1-2&keywords=headphone+volume
These won't interface with the volume controls of your operating system, but they should serve the same purpose, and you could max out the slider on your PC to give you the full spectrum of control on the volume knob adapter.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6859311
Eh, not quite what I'm looking for but close. I just want a knob on my desk to control either my headphones or my speakers.
And I just bought a new pair of headphones so I wont buy new ones for a while.
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6859376
Do you want a knob that connects only to the PC, and controls the volume in the operating system? The same as using media keys on your keyboard, but with a knob.
I'm not aware of any standalone devices for doing that, but there are other devices that may work, such as this (first thing I found on Amazon).
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6859656
Here. It's primarily a volume knob, but also has several other media control functions. From the reviews on the product page, it seems like you can map anything to it.
http://www.amazon.com/Griffin-Technology-NA16029-Multimedia-Controller/dp/B003VWU2WA/ref=sr_1_1?s=pc&ie=UTF8&qid=1451398685&sr=1-1&keywords=usb+volume+knob
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6860443
Not really. Your best bet is probably a keyboard with multimedia controls.
There are a few things that exist
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6860620
Does that have support for windows 7+?
Hmm,looks like not very well, but it can kinda be done.
So yeah, not the best option
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6861021
If it is for controlling speakers, or an amp from RCA inputs there is the Emotiva Control Freak
Internets Machine: Intel 4690k w/ Be Quiet! Pure Rock 4.7Ghz. MSI Krait z97. 16GB Crucial Ballistix Sport Ram. MSI GTX 970 SLI 1520mhz. 500GB Samsung EVO 840  & 3TB WD Blue Drive. Rosewill 1000w Modular PSU. Corsair Air 540
My Beats Yo: Desktop:SMSL SA-160 Amp, KEF Q100 w/ Dayton 100w Sub Theater: Micca MB42X-C x3, MB42X x2, COVO-S x2 w/Dayton 120w Sub Headphones:  HIFiMan HE-400i, PSB M4U2, Philips Fidelio X2, Modded Fostex T50RP, ATH-M50, NVX XPT100, Phillips SHP9500, Pioneer SE-A1000, Hyper X Cloud 1&2, CHC Silverado, Superlux 668B
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6861528
That's exactly what I want. Is there huge difficulties in using it with windows 10?
https://linustechtips.com/topic/515711-physical-volume-knob/#findComment-6862280
Guest
