something like the Silverstone Raven RVZ01 case or like the Asus ROG G8 PC
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/515700-thin-itx/#findComment-6859044
  • 2 weeks later...
Mini-ITX that's about as high as a single Ethernet or dual USB socket (aka thin ;)).
Edit: All the above are not, RVZ01 and 202 are mini-ITX and the G8 is proprietary.
The Node 202 is a Mini-ITX case, since the biggest motherboard is supports is a Mini-ITX motherboard
Here is a Mini-ITX motherboard: https://www.asus.com/Motherboards/P8Z77I_DELUXE/
And here is a Mini-ITX case: http://www.fractal-design.com/home/product/cases/node-series/node-202
ATX compare
https://linustechtips.com/topic/515700-thin-itx/#findComment-6926547
Yes but OP was asking about thin-ITX not mini-ITX ;)
https://linustechtips.com/topic/515700-thin-itx/#findComment-6936422
