first cpu water loop
Go to solution Solved by WunderWuffle,
242.70 + shipping 14.6 for shipping and plus $7 dollars for fittings
You should be getting an AIO if you want a budget watercooling loop. Can you get the H220 where you live?
We cant see your cart.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-688955
You will not be getting better temps than an AIO with that kind of setup.
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-688970
You should get at least a 240 RAD, otherwise an H100i would perform better and be cheaper.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-688985
ok if i get a 240 rad i can mount it to the back of my case with fan mounts
You have a 120.2 rad mount on the back of your case?
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689027
yea
Do you plan on W/C'ing your GPU later down the road?
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689055
not really
What's your budget? How much does that loop cost in total?
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689071
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689108
You might want to consider getting that.
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689124
ok cheers in just asking would be able to mount it to a 120mm fan slot with the 80mm to 120mm radiator brackets ?
If you can find adapters, and the adapter can support the weight of the rad, you can do it.
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689149
ok cool i found some on ebay thanks for the help mate
No problem.
https://linustechtips.com/topic/51567-first-cpu-water-loop/#findComment-689166
