I started using my main rig again today after a while, and I remembered I could never open geforce experience on it. I know I can manually update my drivers, but I haven't been able to open it for around a year and its really annoying. Every single time i try to open it, it doesn't do anything for around a minute and then a box pops up saying its encountered an error and must close. I asked on the geforce forums around 8 months ago and got 1 response and the fix only worked for 1 start up and the problem persisted.
https://linustechtips.com/topic/515626-geforce-experience-issue/
reinstall
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/515626-geforce-experience-issue/#findComment-6858181
I've tried that around 10 times over the course of the past year
aw crap.
That's what I do whenever GFE doesn't open up (twice now)
Try running as Administrator
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/515626-geforce-experience-issue/#findComment-6858260
