lubuntu help
Go to solution Solved by patrick3027,
Lubuntu comes with AbiWord and Gnumeric pre-installed. They should handle Word and Excel files without problem. If you don't like them, try LibreOffice like has been said above.
+1 for Audacity
EDIT: here's a list of the programs Lubuntu comes preinstalled with https://wiki.ubuntu.com/Lubuntu/Applications
After facing multiple problems with other OS
- http://linustechtips.com/main/topic/514890-windows-xp-activation-help/
http://linustechtips.com/main/topic/514943-windows-10-installation-on-512mb-ram/
http://linustechtips.com/main/topic/515116-best-linux-distro-alternative-for-windows-xp/
i have decided to use lubuntu. However being new to lubuntu i need to know the following.
- is there a built in program that can record voice from microphone
- best microsoft office alternative
Thanks.
https://linustechtips.com/topic/515534-lubuntu-help/
Libre Office is the best MS office alternative. Ummm? Does Audacity support Linux? if it does then you'll be golden if not then RIP.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/515534-lubuntu-help/#findComment-6857334
Audacity is supported on Linux, and Libre Office is excellent. I'm not sure how well it will run on low ram though.
Lord of Helium.
https://linustechtips.com/topic/515534-lubuntu-help/#findComment-6857433
+1 for Audacity
Why is SpongeBob the main character when Patrick is the star?
https://linustechtips.com/topic/515534-lubuntu-help/#findComment-6858498
