Hey guys, I'm looking to build my first gaming PC and I already have a parts list put together. I'm planning to build this around May or June so prices may change a bit but I was wondering if there's anything I should change to improve performance around the same budget? Budget max is around $1100-1200 USD and hoping to run current gen games at high settings, 60fps with a single 1080p monitor.
Thanks.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($92.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($81.49 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB Video Card  ($308.99 @ SuperBiiz)
Total: $1178.32
Generated by PCPartPicker 2015-12-28 15:51 EST-0500
https://linustechtips.com/topic/515285-first-gaming-pc-build/
Thanks.
Total: $1178.32
I'd go with a skylake system with the i5-6600k instead, it wont bottleneck you in games and is cheaper  than the i7 4790k.
https://linustechtips.com/topic/515285-first-gaming-pc-build/#findComment-6854326
Get a R9 390 over the 970. It beats the 970 at all resolutions (even when both are overclocked) and has 8gb of vram, which mean it'll be more relevant in the future.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/515285-first-gaming-pc-build/#findComment-6854332
lol.. i would take 4790k over i5 anyday since op included it i guess it fits his budget..
and some games run better with the i7, fallout 4, crysis 3 etc.
and 390 vs 970 is dependent on what games you play...
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515285-first-gaming-pc-build/#findComment-6854347
Id still take Skylake for the newer platform, but if you can add around $50 more get the 6700K
As for the 390 vs 970 I agree, and gap is much closer than some realise, gameworks games the 970 > 390
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/515285-first-gaming-pc-build/#findComment-6854384
I disagree if you watch Jayztwocents' video the 390 was basically whooping the 970 in every game.. and AMD cards age much better so far than Nvidia's
We're all dying slowly
Pentium G3258 3.2 ghz / ECS z97 pk MOBO / Intel Stock Cooler / R9 290 DD / Corsair Carbide Air 240 / 4GB mushkin stealth ram at 1600 / XFX 650W 80+ gold PSU / Kingston v300 240GB drive W/300GB seagate drive / HP x2301 / Gateway KB / Monoprice GM
https://linustechtips.com/topic/515285-first-gaming-pc-build/#findComment-6854397
Its less than 5% per game, also in the gameworks title (Witcher 3) as I said, the 970 wins.
390 is still a great card none the less
Ryzen Ram Guide
https://linustechtips.com/topic/515285-first-gaming-pc-build/#findComment-6854501
