Hi all,
I'm in the process of choosing components for my new build (first in quite a while), but I feel extremely overwhelmed by all the choices.
So, here are the things I'm decided on:
Purpose: Gaming, Workstation.
Budget: Open.
Overclocking: No or factory.
SLI: No.
4K: Yes.
Moding/Ricing: No.
Storage: 1x 250GB SSD, 1x WD Black 6TB HDD, No RAID*.
GFX: 1x GeForce 980 Ti 6GB DDR5
RAM: 32GB min.
CPU: Intel Core i7
Case: Dust and rust proof (I live near the sea so this matters)
Monitor: Don't need a new one right now.
What I need help with:
Storage: Which SSD?
GFX: Which 980 Ti?
RAM: What kind?
CPU: Which model? (I do a LOT of compiling/processing)
Case: Which? The smaller the better (e.g. microATX), meeting all other requirements is more important though.
Motherboard: No idea what to do here. Has to fit the case, ofc.
Cooling: No idea.
PSU: No idea.
Keyboard: I play FPS games mostly, macros don't matter, backlit doesn't matter, mechanical doesn't matter, build quality does, numpad does.
Mouse: No idea.
Am I forgeting something?
Would appreciate any and all suggestions.
Cheers.
https://linustechtips.com/topic/515202-building-a-decent-linuxsteamos-rig/
I'd suggest going for an X99 chipset with a good 128GB support motherboard and the i7 5820K(I know this chip doesn't support 128GB) For the price, it's almost silly to go with Haswell and Is silly to go for Skylake when a 6-core 3.3Ghz CPU is there.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
Hi all,
Decent GNU/Linux gaming rig doesn't exist, your best bet is doing a GPU hardware passthrough to a windows virtual machine for games, and Nvidia apparently tries to block you from doing such with a "code 43" error, when you try to passthrough the GPU, but there's an easy fix
Do you already have a 4k display?
the 980ti generally isn't worth getting, what software? do you really need CUDA?
Mostly what budget what country?
You better stick to 1440p on Linux based OSs... >.<
BECAUSE AMD AND NVIDIA HAVE THEIR HEADS IN THEIR ASSES!!!
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
Decent GNU/Linux gaming rig doesn't exist.
The thing is, I'd only (re-)started gaming to support Linux as a gaming platform (been a Linux user for well over 10 years), but then I sorta got sucked into the game, and that is when I discovered that my current system is not quite up to the task, because it was bought with power, not gaming, in mind. I'm already in the final stages of repurposing it into a powerful entertainment hub/media center (got it an mSATA SSD, a DVB set, a Steam controller, and hooked it to the TV), but I digress. My point is, all my favourite titles are already Linux-native (e.g. 7 Days to Die, CS:GO, TF2, DiRT Showdown, etc..), I'm just attempting to future-proof my workstation for the growing list of native Linux/SteamOS titles, so I don't feel impotent when surprise releases (like Dying Light) happen. But I really have little to no interest in Windows gaming.
I do intend to use GPU passthrough, but only as an evolution of my current gaming habits, not as prime purpose of this build.
No, and I have no place on my desk for a new monitor right now, but I do want my system to be 4K-ready.
I was just going for the most powerful Nvidia GPU out there, without going overboard with a Titan. I'm still open to suggestions though. Being an Nvidia card is the only prerequisite, besides power.
Egypt (http://www.egprices.com/en/category/computers ),but I have an easy access to international shipping, with the only exceptions may be the case, because shipping it would probably cost more than its retail price. Budget is open as mentioned in the OP.
Cheers.
This here. If anything you should get windows 8.1 or 10 as your main OS and then make a second partition on your ssd to do a dual boot for linux. Windows is going to have much better compatibility for gaming and other programs. Not to mention if you're going to go with SteamOS as your OS, that is a terrible idea and a complete waste of money and equipment, especially considering games which "support" SteamOS have terrible frame rates and run like shit.
Well as far as gaming and performance per dollar is concerned you're better off with a mid range AMD card and a free-sync display over a 980 ti
or buy a solid 4k display first, no reason to waste money on any high end GPU before you have a display that can actually utilize it.
You convinced me to buy a gaming laptop (again).
must have missed your last post, but future proofing isn't really real, and as far as AMD's linux support goes as soon as vulkan drops AMD is looking to gain a decent advantage over nvidia as it's using parts of mantle like how DX12 is, and nvidia cards have issues with asynchronous compute, also isn't like everyone terrible with linux basically?
But again, you can't exactly game on linux very well still.
and you'd only be losing a lot of performance per dollar going with a laptop. but if you truly want a desktop replacement laptop you'll have to look to Eurocom
or something like this which has a desktop i7 in it
https://www.originpc.com/gaming/laptops/eon17-x/
Well, as long as you're realistic about it, it sorta is.
I'm not holding my breath, AMD had always promised better support for Linux, but they never delivered, their next step is to opensoure their drivers, which is probably their best and only shot to beat Nvidia at Linux support, as they seem to lack in-house talent.
Not exactly, Nvidia proprietary drivers have been on bar with their Windows' drivers for quite a while, though their open drivers are even worse than AMD's, so everyone is terrible in their own way. Also, as Linux gaming gains more steam, companies are racing to dominate that niche.
I can, and I do.
About that, I'm not so sure actually, the thing is, if I bought local, I'd probably pay about the same (or even save a little) by going mobile, because Laptops are less taxed than high-end computer components here (aprox. 8EGP/USD vs 10EGP/USD, i.e. 20% cheaper), and since I'm not planning to OC, or upgrade soon (if that's even viable, with Pascal, Skylake and other new architectures set to take over within the next year), I don't see a point in switching to desktop at this very moment. Maybe in the near future, when the dust had settled on all the new technologies coming out in 2016-2018. Also, I'm pretty good at repurposing old laptops once they become obsolete, I have no idea what to do with the big hunks of metal that are desktop towers.
I've checked out several "custom" gaming laptops (here, here and here), and I still don't see the point. First of all, they all seem to be clones of each other, or some better known brands, and their prices don't really make sense, unless you really want to support the small-time manufacturers. Could you please tell me what advantages they have over, say this MSI Dominator Pro? (27800EGP~=3500USD)
What are you compiling?
I'm a developer, and I also use a non-binary Linux distribution, so my CPUs are busy pretty much 24/7.
Like anything you buy now is going to be outdated in 2 years or so, usable sure, especially if it's a high end part, but still outdated comparatively. Well aside from a nice case
So long as the laptop has the desktop CPU you're set for desktop replacement, if it costs about the same well, might as well go for the laptop in that case.
