my fren computer got bluescreen problem
here is the spec
i5 3570k no overclock
intel stock cooler
asus p8z77-v lx
asus gtx670 direct cu II OC (FACTORY OC)
cooler master m2 620watt
1tb caviar blue/black (i forgot :P)
Cooler master k380
kingston ram 1600mhz 4gb single channel
old dvd rom (no problem)
software
window 7 ultimate 64bit
after he install window 7 , he only download 3.0usb driver from asus web and does not insert motherboard dics install other driver example intel blah blah , he used around 2weeks and start bluescreen , about twice a day or more , i asked him to install the driver , after install its still the same problem !
guys help :(
https://linustechtips.com/topic/51441-my-fren-computer-got-bluescreen-problem/
we need to know what kind of error is causing the blue screen to help you but, before you try find out try swapping the RAM sticks with something else RAM malfunctions and problems are quite common causes of Blue screen of death
My Current Rig: CPU: i7 4790k @ 4.8Ghz CPU Cooler: H100i MOBO: Gigabyte Z97X SOC GPU: XFX Radeon HD 7950 Tahiti pro (Died 6/07/2014 RIP) & PowerColour HD7950  GPU Cooler: NZXT G10 W/ Corsair H55 HDD&SSD: Seagate Barracuda 1TB + Corsair GS 128GB + Samsung 840 EVO 250GB PSU: Corsair RM 750 Case: Fractal Design Arc Midi R2.
Please follow the advice on this thread and upload the dump files to the forum for further analysis. That way we can try and figure out what has caused the BSOD and how to fix it. There are literally thousands of causes of a BSOD, so we need some more information.
HTTP/2 203
