Hi guys, hoping someone can help me. Just finished putting together my new rig and it won't post, I've tested it in different scenarios and still nothing.
Observations I have made:
No beeps etc from motherboard
All components reseated to no avail
error message on monitor changes from "Check Signal Cable" To "No Signal" when I turn on my pc
Fans spin and mobo LEDs light up for between 5 and 30 seconds before shutting down again
I/O will power my mouse but not my keyboard. Tried changing the USB to different places but still nothing. Keyboard is not dead, tested with other computer
different display cables tried.
I hope you can help me. Thanks, my specs are on my profile page if they are useful
https://linustechtips.com/topic/514337-pc-wont-post/
No beeps... installed the speaker?
My (unprofessional) opinion otherwise: You might have bricked your board somehow.
Or just not the correct cables connected.
Theory is when you know everything but nothing works. Practice is when everything works but you dont know why. In this computer, theory and practice are combined: Nothing works and i dont know why.
Atleast i can manage Some things, like my current OC personal best.
https://linustechtips.com/topic/514337-pc-wont-post/#findComment-6844406
The speaker which would make the error beeps is integrated into the motherboard. Yes I'm worried I might have a dead mobo
Are you ENTIRELY sure you have an integrated speaker? My Asus Z170 board does not.
https://linustechtips.com/topic/514337-pc-wont-post/#findComment-6844443
the speaker on your motherboard is only for error beeps, not for anything else..
https://linustechtips.com/topic/514337-pc-wont-post/#findComment-6844459
