Im tired of my fans running all the time.
Is there any way to make my fans stop when the system is not doing anything / idling / light load?
I dont want to have a switch to stop them myself, i want them to do it automatically :)
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/514107-auto-fan-control/
Speedfan would be best tool for it. It uses CPU temp (or GPU temp) as reference. Its bit difficult to config but results are well worth it.
I have that, but for some reason i cant open up speed fan. Ive seen some videos from linustechtips, where he uses a mcubed tbalancer. Do you know how that works?
Built  Not Bought
https://linustechtips.com/topic/514107-auto-fan-control/#findComment-6842989
I know its hardware controller which doesn't have any display. Hence Linus calling it hard to config.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/514107-auto-fan-control/#findComment-6843033
So the only real thing to do is trying to make Speedfan work again?
Built  Not Bought
https://linustechtips.com/topic/514107-auto-fan-control/#findComment-6843057
Well there are NZXT Grid+ and Corsair Commander Mini if you want hardware controller. I think both have fan curve capability but I don't know if they alow 0rpm fans.
https://linustechtips.com/topic/514107-auto-fan-control/#findComment-6843084
I will look into that then, thanks :-)
Built  Not Bought
https://linustechtips.com/topic/514107-auto-fan-control/#findComment-6843233
I would look into your MoBo's UEFI too. Just about every consumer board is shipping with some kind of built in fan control now.
My z97x-soc has plenty of fan control, but im not able to make my fan stop completely. They aren't loud. But I want them to stop when system is not pushed.
Built  Not Bought
https://linustechtips.com/topic/514107-auto-fan-control/#findComment-6843597
