So I have the GTX 980 SC and it peaks at like 70C under like 60% load. Good or bad?
Your airflow is not that good then
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/514023-gtx-980-temps/#findComment-6841625
hard to tell if its not 100% (or closer to) load temps
that is a reference cooler right?
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/514023-gtx-980-temps/#findComment-6841631
Yeah reference. And actually it's at 70C both at 70% and 100% load so I'm good?
yeah, if you are staying at 70c under full load that is great and you could probably reduce your fan speeds a little. However Some full load temps will be different than other full load temps so good to keep an eye on it. Or just set a curve that really ramps up rpms around 80 to be safe
https://linustechtips.com/topic/514023-gtx-980-temps/#findComment-6849149
Don't look at the laod alone. The power draw measured in % of the TDP is more important when it comes to thermals.
HWmonitor can read it for example.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/514023-gtx-980-temps/#findComment-6850177
