K I'll try that, and it is really cheap.
Novus makes some really good polishing compound, but in general plastic windows will scratch overtime. Other than replacing it with a glass pane which is not as easily scratched there isn't too much that can be done:
http://www.amazon.com/NOVUS-7100-Plastic-Polish-Kit/dp/B002UCYRZU
https://linustechtips.com/topic/513607-need-side-panel-help/#findComment-6837677
K How could I get it replaced with glass if I wanted to?
https://linustechtips.com/topic/513607-need-side-panel-help/#findComment-6837760
If you wanted to replace it getting a piece of glass cut at a local window or door shop isn't too expensive but to fasten it in place you will need to remove the old panel and those metal tabs that hold it in place to either double side stick or silicone the glass into place if you want not gap between the panel and glass from say double side tape.
If your interested I have some info on it under Window Mod just disregard the cutting portion for adding in a window:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
https://linustechtips.com/topic/513607-need-side-panel-help/#findComment-6837831
