980 SLI Issues
Solved by Thx And Bye,
If you disable SLI and connect the display(s) just to your second new card, does it perform identialy to your other old card?Certainly it is enabled. I wouldn't have had screen flashing issues otherwise...
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
