hello i recently got a new saphire radion r9 390x. i putt the card in my system nothing happend so i looked at the manual and it said 750w power supply so i did some research and many articals said that is could run on a 600w power supply (what i currently have) so i figgerd i should just order a power supply but
then i thought maby it was d.o.a  butt i was wondering if it could maby work on a 600 w power supply
the anwsers were not very clear to me i would appreciate the help thanks
psu is  a
tr2 600w by thermal take
https://linustechtips.com/topic/513258-need-help/
what PSU do you have? Exact model?
https://linustechtips.com/topic/513258-need-help/#findComment-6834440
600W is more than enough for 390x.
But what's the model of PSU tho?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/513258-need-help/#findComment-6834443
Depending on the specific PSU you´ve got. A single 12V rail with good rating is enough, a multi rail isn´t.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/513258-need-help/#findComment-6834455
my psu is a
tr2 600w
Your PSU is the single worst PSU available on the market. I bet my ass it's the issue
https://linustechtips.com/topic/513258-need-help/#findComment-6834494
exacly what i was thinking its super loud as well thank you for the help
Grab a XFX TS 650W
https://linustechtips.com/topic/513258-need-help/#findComment-6834500
my psu is a
tr2 600w
Buy something like EVGA G2/GS/GQ or any Seasonic.
https://linustechtips.com/topic/513258-need-help/#findComment-6834529
i already orderd a  evga spuernova 750 w do you think this woud be ok i felt like it was a good deal it was on sale
It's a good one.
If it is a NEX branded, cancel the order and buy a G2/GS/GQ.
https://linustechtips.com/topic/513258-need-help/#findComment-6834552
EVGA G1, B1 and NEX are crap
W1 are absolutely horrible
https://linustechtips.com/topic/513258-need-help/#findComment-6834553
It's a good one.
G1 and B1 are also SuperNOVA branded and are also crap
https://linustechtips.com/topic/513258-need-help/#findComment-6834554
Yeah.
But NEX is on sale now. That's why I mentioned that. :)
https://linustechtips.com/topic/513258-need-help/#findComment-6834557
so dont buy it or go threw?
Don't buy it if it is a NEX, G1, V1, B1, W1.
Buy only if it is GS/G2/GQ or anything from Seasonic. or XFX TS.
https://linustechtips.com/topic/513258-need-help/#findComment-6834570
so shouled i grab a
XFX TS 650W
Yea, It's a good one.
https://linustechtips.com/topic/513258-need-help/#findComment-6834599
just out of curiosity would the
EVGA SuperNOVA 750  work or no
EVGA SuperNOVA has many sub branding like EVGA SuperNOVA B1, EVGA SuperNOVA G1, EVGA SuperNOVA W1, EVGA SuperNOVA NEX.
        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^Those are not good.
Only EVGA SuperNOVA G2, EVGA SuperNOVA GS, EVGA SuperNOVA GQ are good.
https://linustechtips.com/topic/513258-need-help/#findComment-6834636
butt would the b1 power the card
https://linustechtips.com/topic/513258-need-help/#findComment-6834643
It's a crappy PSU.
Technically 750W is overkill for that card.
But don't buy that PSU for your own good.
https://linustechtips.com/topic/513258-need-help/#findComment-6834652
so it would work but dont buy it
exactly.
https://linustechtips.com/topic/513258-need-help/#findComment-6834659
