and why is it so bad?
Poor soldiering, Cheap and Bad crappy capacitors.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/513258-need-help/page/2/#findComment-6834670
idk if it works i might go for it
Don't cheap on selecting PSU.
It's the most important component on your system.
Consider getting one from these
http://pcpartpicker.com/part/evga-power-supply-210gq0650
http://pcpartpicker.com/part/seasonic-power-supply-s12ii620bronze
https://linustechtips.com/topic/513258-need-help/page/2/#findComment-6834695
the 50 dollar price is a bit tempting thoe
This has been stated by a shit ton of people before they fried their hardware, not sure if you would want to count yourself into that circle... the one that cheaps out deliberately on a PSU deserves to struggle.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/513258-need-help/page/2/#findComment-6834714
going to best buy now thx for the help mate hope you had a great xmas :)
https://linustechtips.com/topic/513258-need-help/page/2/#findComment-6834760
You too.
https://linustechtips.com/topic/513258-need-help/page/2/#findComment-6834779
