It'll be easier to troubleshoot if you take everything apart. But here's one more thing: Check if your CPU 8pin power is plugged in correctly all the way in. Other than that I think you've done pretty much everything.
If a pin in the cpu socket is bent, how can I fix that?
Core i5 4690k @ 3.8 GHz |  Hyperx Fury 8gb ddr3 1600mhz  |  GIGABYTE Z97-MX Gaming-5  |  Cooler Master Hyper T4  |  XFX R9 390 8gb  |  Corsair CX750M  |  NZXT H440 Black & Blue  |  Samsung 850 EVO 240gb  |  WD BLUE 1TB  |  ASUS VG248QE 144hz & ASUS VX238H
https://linustechtips.com/topic/513086-help/page/2/#findComment-6835713
RMA the board and tell them you received the board like this :P.
CPU: AMD Ryzen 5800X GPU: Nvidia RTX 3080 12GB + Motherboard: Asus Crosshair VIII Hero
  Case: Asus ROG Strix Helios Gundam Edition Power Supply: Asus ROG Thor 850P
https://linustechtips.com/topic/513086-help/page/2/#findComment-6835774
The guy who helped me pick parts at MicroCenter agreed to help me assess the issue, but thanks for all the help and patience.
https://linustechtips.com/topic/513086-help/page/2/#findComment-6836630
So I tried 2 psus and 2 motherboards. The computer turns on, but if any peripherals are connected to the psu the pc will not turn on.
https://linustechtips.com/topic/513086-help/page/2/#findComment-6848279
did you assemble out od the case at all?
I assembled the motherboard out of the case, if that is what you mean.
https://linustechtips.com/topic/513086-help/page/2/#findComment-6851199
i meant did you assemble and run out of the case ( breadboard )..??
No.
https://linustechtips.com/topic/513086-help/page/2/#findComment-6851868
lol rip
[CPU] Ryzen 5 3600x [Cooling] be quiet! Dark Rock Pro 4 [Mobo] B450 Tomahawk Max [RAM] 16GB (2X8) Corsair Vengeance LPX 3000MHz [GPU] RTX 2070 Super Gaming X Trio [PSU] XFX XTR 750W [Case] Fractal Design Define R5 Windowed
https://linustechtips.com/topic/513086-help/page/2/#findComment-6854818
lol rip
It wasn't a bent pin. MicroCenter is currently diagnosing it. Imagine if I put your reply as the solution
https://linustechtips.com/topic/513086-help/page/2/#findComment-6855299
