I don't know where to put this, so it is here. I have just built my first pc that I've been saving up for, for a year (2 Christmas'). I just finished the build, and I turned it on. Nothing but a little green light on the motherboard. I party with my family for Christmas all day, then I turn it on again. Now nothing happens at all. Is the power supply dead? Motherboard dead?
Build: http://pcpartpicker.com/p/VPTKzy
Core i5 4690k @ 3.8 GHz |  Hyperx Fury 8gb ddr3 1600mhz  |  GIGABYTE Z97-MX Gaming-5  |  Cooler Master Hyper T4  |  XFX R9 390 8gb  |  Corsair CX750M  |  NZXT H440 Black & Blue  |  Samsung 850 EVO 240gb  |  WD BLUE 1TB  |  ASUS VG248QE 144hz & ASUS VX238H
https://linustechtips.com/topic/513086-help/
Can you send a pic?
Mobo-Gigabyte GA-Z97-HD3 LGA 1150   RAM-Crucial Ballistix Sport 8GB Kit (4GBx2) GPU-GTX 960 Overclocked 4GB Windforce  Case-Sentey Gs-6008 Plus Stealth  Sorage-WD Black 1tb HDD + SanDisk SSD 250GB  PSU-Sentey 750w 80 Plus Bronze  Cooling-Corsair Hydro Series H60  CPU-Intel Core i5-4690K
https://linustechtips.com/topic/513086-help/#findComment-6833113
Can you send a pic?
Sorry, but not at the moment. Everything is plugged in correctly though.
https://linustechtips.com/topic/513086-help/#findComment-6833131
Do you have it off or on atm?
https://linustechtips.com/topic/513086-help/#findComment-6833133
A R9 390? with 650 watts?
Maybe there's not enough juice going to the PC?
650 watts should be fine
Make sure that its off then reseat the RAM
https://linustechtips.com/topic/513086-help/#findComment-6833140
So turn off the power supply, then unplug and replug the RAM? I will make sure to check every RAM slot. I cannot work on it atm, but in the morning I can, so can you please tell me more potential solutions?
https://linustechtips.com/topic/513086-help/#findComment-6833160
pull the graphics card. hook monitor to motherboard. reset cmos. boot with 1stick of ram.
If this still doesn't work and you get no post make a new forum tomorrow
https://linustechtips.com/topic/513086-help/#findComment-6833174
Ok. Hopefully see you (or someone else) then :)
https://linustechtips.com/topic/513086-help/#findComment-6833181
So, I just reseated the ram. Did nothing. Reset CMOS. Did nothing. Used one stick of ram. Nothing happens. All of these tests didn't have the gpu in, but isn't it ok because the cpu has integrated graphics?
https://linustechtips.com/topic/513086-help/#findComment-6834910
Can you send a pic?
post-292167-0-67473500-1451141623_thumb.
post-292167-0-26131400-1451141651_thumb.
https://linustechtips.com/topic/513086-help/#findComment-6834940
^bump?^
https://linustechtips.com/topic/513086-help/#findComment-6835041
So when you press the power button , nothing happens? At all? If so , see if you plugged the power switch correctly. But before that , remove the power switch cable and use a screwdriver to short the 2 pins (put the tip of the screwdrivers on the 2 pins , check the manual) on the motherboard to turn it on manually.
CPU: AMD Ryzen 5800X GPU: Nvidia RTX 3080 12GB + Motherboard: Asus Crosshair VIII Hero
  Case: Asus ROG Strix Helios Gundam Edition Power Supply: Asus ROG Thor 850P
https://linustechtips.com/topic/513086-help/#findComment-6835416
Now a green light turns on (not from your suggestion, from another), but nothing else.
https://linustechtips.com/topic/513086-help/#findComment-6835433
Does it turn on when you press the power button?
https://linustechtips.com/topic/513086-help/#findComment-6835447
No... Just a green light on the motherboard.
https://linustechtips.com/topic/513086-help/#findComment-6835460
Try what I said earlier. I don't think it's the power supply. Might be a broken power switch.
https://linustechtips.com/topic/513086-help/#findComment-6835467
I did the screwdriver thing, but nothing happened.
https://linustechtips.com/topic/513086-help/#findComment-6835479
Would this mean the motherboard is messed up?
https://linustechtips.com/topic/513086-help/#findComment-6835520
No it means the power switch is fine xD. Anyway , try taking out the motherboard from the case and plug in everything except the graphics card, sata cables and front panel audio , usb. After that see if it turns on. If it doesn't , try using different RAM sticks in different slots. If nothing works , take out the cpu and check for bent pins.
https://linustechtips.com/topic/513086-help/#findComment-6835619
Are there any other solutions that don't involve taking everything apart?
https://linustechtips.com/topic/513086-help/#findComment-6835674
It'll be easier to troubleshoot if you take everything apart. But here's one more thing: Check if your CPU 8pin power is plugged in correctly all the way in. Other than that I think you've done pretty much everything.
https://linustechtips.com/topic/513086-help/#findComment-6835706
