Earlier this week, I came home from work to find that my pc would not turn on. The power supply was fine but I went to buy a new one to test. with the old PSU in, I connected the CMOS jumper pins as a last attempt before I just gave up. For some reason, doing this actually allowed ny pc to boot!
I installed the new PSU and everything was working fine. I played games, shut it down, and come back later and played.more games. Everything was working as it should.
I came home today from Christmas stuff and my pc wouldn't come on once again. I have checked the wires, jumped the cmos , but it will not start. I'm kind of at a loss here. help would be greatly appreciated.
https://linustechtips.com/topic/513054-pc-does-not-turn-on/
I'm not a expert but maybe your motherboard is failing? Does it litterly not turn on (So when you press the power button not even the fans spin up) or is it going with no video? Describe plz
Wow this was old as heck, Need to update this signature!
https://linustechtips.com/topic/513054-pc-does-not-turn-on/#findComment-6832856
I've only had the motherboard a month.
When I press the power button, nothing.happens. no fans, no nothing, no lights.
Hmmm seems like a PSU problem but it cant be because you changed it... Maybe the cables are damaged? OR did you replace them with the new PSU?
https://linustechtips.com/topic/513054-pc-does-not-turn-on/#findComment-6832919
