So when luanching a game of CS:GO my 390x ramps it's fan speeds up to %100 and when playing GTA V it runs at 88 degrees. Is this normal?
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/512776-390x-fan-problems/
In GTA, this is a normal temperature, considering the 390X is a hot-running card.
As for CS, it may have something to do with fan profiles, but, if the fans spin down again, it shouldn't be an issue
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830131
and even at idle my fans are spinning and the card is at 55 degrees and below 60 degrees the fans are supposed to not spin
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830135
Did you do anything on fan profiles?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830148
Set up a custom fan profile. That's what I did with my 960, and now it's silent
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830154
No I don't think so
and how do i do that
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830164
No I don't think so
Use Afterburner to create custom fan profile.
Like this
900x900px-LL-a618d001_custom_fan_curve.j
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830184
MSI afterburner, there are loads of videos describing the process on youtube
https://linustechtips.com/topic/512776-390x-fan-problems/#findComment-6830186
