GTX 960 Work?
Go to solution Solved by DavidLT06,
Ok thankyou all :P
They will work but not fine cause the a6 is going to be a pretty huge bottleneck.
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827713
What cpu should i get
Thankyou.
What is your budget?
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827732
Is it better than 960 4gb tho ?
Yes. But if you get the 380, make sure you get the 4GB model.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827736
£150
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  (£89.50 @ CCL Computers)
Motherboard: ASRock B85 Anniversary ATX LGA1150 Motherboard  (£60.00 @ Amazon UK)
Total: £149.50
Generated by PCPartPicker 2015-12-25 13:57 GMT+0000
If you can use ur current ram if not + 35£
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827746
Thankyou.
It is better than a 960.
Skylake build here!
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (£95.99 @ Novatech)
Motherboard: Gigabyte GA-B150M-D2V DDR3 Micro ATX LGA1151 Motherboard  (£49.20 @ Aria PC)
Total: £145.19
This ^. You can use the DDR3 module from the old build.
Or this Haswell build here
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£31.49 @ Ebuyer)
Total: £120.99
Generated by PCPartPicker 2015-12-25 13:58 GMT+0000
30 pounds cheaper.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827748
Thankyou.
Now im going to buy R9 380 will it still bottleneck ?
With an i3 not but with your current cpu yes.
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827761
Thankyou.
It will be worse, get the 960 4GB if you've no plan to upgrade to at least i5 or Skylake i3.
https://linustechtips.com/topic/512518-gtx-960-work/#findComment-6827773
