ok guys im gonna list down all the parts that i thought up so please tell me if it's all compatible with one another, if it can run all the latest games (E.g. witcher3,dragon age inquisition and assassins creed syndicate) and lastly tell me Your feedback on what i should do to improve it or if something is wrong or if this part is better TNX in advance
HDD
Western Digital 1 TB           50.83$
RAM
GSKILL RIPJAWSX 8GB   44.47$
PSU
CORSAIR VS450 450W      37.06$
Case
THERMALTAKE VERSA H21 42.25$
DVD-ROM
I can re-use my old pc's dvd
MOTHERBOARD
MSI H81M-P33 51.88$
GPU
PALIT GEFORCE GTX 750 TI 2GB DDR5 128BIT OC STORMX 122.83$
OR
EVGA GEFORCE GTX 750 TI SC 2GB DDR5 164.12$
OR
POWERCOLOR TURBODUO R7 260X OC 2GB 116.47$
CPU
INTEL PENTIUM G3260 DUAL CORE 59.30$
TOTAL
PALIT GTX 750TI 408.62$
EVGA GTX 750TI 449.90$
POWERCOLOR R7 260X 402.26$
the amount of money i can spend on building a pc is only around 400$
and whats the difference between the evga 750ti and palit 750ti
and is r7 260x much better than the750ti?
https://linustechtips.com/topic/512506-help-me-build-a-pc/
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($99.99 @ Micro Center)
Motherboard: Asus B85M-G R2.0 Micro ATX LGA1150 Motherboard  ($36.98 @ Newegg)
Video Card: PowerColor Radeon R7 370 2GB PCS+ Video Card  ($113.98 @ Newegg)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($31.99 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($53.99 @ SuperBiiz)
Total: $420.90
Generated by PCPartPicker 2015-12-25 08:30 EST-0500
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/512506-help-me-build-a-pc/#findComment-6827643
Total: $420.90
Jesus thats an epic build for 420 bucks 3:
Moist
https://linustechtips.com/topic/512506-help-me-build-a-pc/#findComment-6827699
especially a b85 chipset for $37 is real cheap.
https://linustechtips.com/topic/512506-help-me-build-a-pc/#findComment-6827714
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($66.99 @ NCIX US)
Motherboard: Asus A68HM-K Micro ATX FM2+ Motherboard  ($32.98 @ Newegg)
Memory: A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory  ($34.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($42.00 @ Amazon)
Video Card: HIS Radeon R9 380 2GB IceQ X² OC Video Card  ($169.99 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($43.99 @ NCIX US)
Total: $420.93
Generated by PCPartPicker 2015-12-25 09:04 EST-0500
The site has changed....
https://linustechtips.com/topic/512506-help-me-build-a-pc/#findComment-6827776
