Can someone link me to a video of a NZXT H440 build tutorial, I need help and I want to watch someone else to build it so I can understand how to build mine. Thank you
Gaming/Editing Rig: CPU - i7 4790K|GPU - GTX 970 SSC|RAM - 16GB HyperX Fury|MOBO - Z97S SLI KRAIT|HDD - 1TB Western Digital|SSD - Samsung 850 EVO 500GB|PSU - SuperNOVA G2 650W
Check out my YouTube channel and maybe subscribe if you get the time? https://www.youtube.com/channel/UCTkGuHFjcWH73lT8RqLK9TA
Check out my digital store for cool products! https://sellfy.com/Zolias
https://linustechtips.com/topic/512458-nzxt-h440-help/
It's fairly simple, like every other case except the PSU shroud.
Well, I asked for a video tutorial, because I'm having trouble. I didn't need your statement now did I? :)
https://linustechtips.com/topic/512458-nzxt-h440-help/#findComment-6827269
Here you go.
But this isn't tough.
Like search this string "NZXT H440 build" on YT.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/512458-nzxt-h440-help/#findComment-6827274
Sometimes it's so sad that LMGTFY links are restricted here :D
ha ha! already aware of that. :P
https://linustechtips.com/topic/512458-nzxt-h440-help/#findComment-6827333
Moved to Cases and Power Supplies.
https://linustechtips.com/topic/512458-nzxt-h440-help/#findComment-6827505
Nice douchey reply
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/512458-nzxt-h440-help/#findComment-6827529
