I have a bootable USB? stick for windows 10 to put onto my ssd
Do I need to delete my os on my hardrive or should I unplug it and set my ssd to the bootdrive and leave my old windows 10 on my harddrive?
Take off all documents and photos off the hard drive. Wipe the hard drive.
Install Windows on the SSD, redirect photo, document, video, and music libraries to folders on the hard drive for mass storage.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821681
Its mostly your choice. But if it were me I'd wipe the HDD, unplug and install windows on the ssd. (then plug the hdd back in after)
Vulcan (Main): Intel Xeon E3-1241 V3 | MSI GTX 1060 Armor OC | G. Skill Sniper 16GB + 4GB @1600  | Crucial BX100 120GB, 1TB WD Caviar Blue, 2TB Seagate Barracuda, 1TB External Seagate Portable | EVGA 650 GQ | Cryorig H7 | NZXT Source 210 Elite
Carbon (Laptop): Lenovo ThinkPad x230 | Core i7 3520m | 8GB Memory (2x4GB)  | 180GB SSD, Sandisk Ultra 128GB SD Card
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821682
Thanks for your advice! My next question is, How do I move all my pictures, games, music, mods for games, games saves etc away from my HD, and how do I wipe my hd?
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821693
move it to another harddrive or a usb.
in windows installation when it says to select a drive first click format then install.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821703
Go to your C: Drive, then Users, then [YourUserName] (Replace that with your username). File path is C:\Users\YourUserName.
Copy all of the folders you want (You probably want to get the Desktop, Downloads, Documents, Music, Pictures, and Videos. Make sure to grab any other folders you need, like Minecraft worlds, steam games, etc.
Once you have your stuff backed up, Install Your OS on and boot from the SSD. With your data backed up, Go to your computer and right click on the Hard drive. Click on format. Format your hard drive, it will be wiped.
For more information:
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821718
no offence, but if you don't know how to move files in Windows I would suggest you get someone to help you before doing a drive format and a Windows install, you might lose files you don't want to.
OR ... If you feel confident enough I would suggest going through a "how-to" tutorial on Youtube...
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821725
I get what you're saying, I just wanted to double check! Merry Christmas!
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821747
no problems, I just wouldn't want you to lose anything because you erased the wrong drive by accident (this happened to me even though I work in the field, overconfidence is a bitch!)
Merry Christmas to you also! And good luck on your install!
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6821873
If I run into any issues can I inbox you? Thanks buddy!
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6822126
no problems I would be happy to help, though it might be long for me to answer from this point forward, I'm leaving for the Christmas holidays, will not be working and I'll be in between family members' couches! lol
https://linustechtips.com/topic/511907-ssd-and-harddrive-issues/#findComment-6822163
