Cpu upgrade problem
Go to solution Solved by Kivi,
Hmm, could be PSU, can you try another one on your rig? Borrow a friends?
Not really but it's a 420w it should be enough
Hey guys, I've just upgradeed to a Q6600 from a Pentium D the rest is unchanged si I have 2x2 gigs of ddr2 800 RAM a GA-965G-DS3 rev 1.0 motherboard with the latest bios but when I start up the pc I see the post screen an then the Windows is starting screen but then it just shuts down
Can anyone help?
Thanks
https://linustechtips.com/topic/511750-cpu-upgrade-problem/
Can anyone help?
Thanks
So you see the windows loading screen but then the pc just literally shuts it self off? It doesn't restart straight away? You have to press the power button to power it back on again?
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/511750-cpu-upgrade-problem/#findComment-6820408
Yes exactly
https://linustechtips.com/topic/511750-cpu-upgrade-problem/#findComment-6820445
I'm not saying it not enough... it could be faulty, a PC shouldn't just die during boot? Can you boot to bios? Does it stay on for more than 10 minutes if you leave it in bios?
https://linustechtips.com/topic/511750-cpu-upgrade-problem/#findComment-6820460
