Do I need a fan controller?
Go to solution Solved by Octavialicious,
8 or 9 fans total.
I mean you could get splitters, but a fan hub would definitely be better imo. This one holds 8 and is high quality (and cheap too!) http://www.amazon.com/SilverStone-Technology-All-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?ie=UTF8&qid=1450892935&sr=8-1&keywords=fan+hub
If you need 9 like you said, you could get this splitter http://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ/ref=sr_1_1?ie=UTF8&qid=1450892968&sr=8-1&keywords=y+splitter+black+fan or  you could plug one fan into the motherboard :)
I'm building a new system next month, and I'm replacing the NZXT fans and adding a couple of other case fans too. I've never added custom fans to a pc build so I'm not sure if I need to get a fan controller, or if I can manage it all from the mobo.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($364.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($125.99 @ SuperBiiz)
Motherboard: MSI X99A SLI KRAIT EDITION ATX LGA2011-3 Motherboard  ($248.34 @ Amazon)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  (Purchased For $0.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.88 @ OutletPC)
Other: NZXT Hue ($59.99)
Total: $1312.27
Generated by PCPartPicker 2015-12-23 12:42 EST-0500
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
https://linustechtips.com/topic/511293-do-i-need-a-fan-controller/
How many fans total? Not sure which fans you're keeping in the case
8 or 9 fans total.
depends if the motherboard has enough fan headers or not
if youre only short by a few then you can just use fan splitters
8 or 9 fans total.
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
http://www.amazon.com/SilverStone-Technology-All-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?ie=UTF8&qid=1450892935&sr=8-1&keywords=fan+hub If you need 9 like you said, you could get this splitter http://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ/ref=sr_1_1?ie=UTF8&qid=1450892968&sr=8-1&keywords=y+splitter+black+fan or  you could plug one into the motherboard :)
Can you use software to control the fan speeds with that?
why so many fans? for the looks?
Partially looks, and I also want high airflow with low noise.
It's PWM so yes, you should be able to :)
Exactly what I need then, thanks for the help!
I didn't want to get a fan controller if I didn't have to because I don't want to add a black controller to the front of my white case, but if I can just mount that inside and plug her in that easy its perfect!
