AIO Cooler Cable Help/Questions
Solved by W-L,
-SNIP-
For the AIO you can choose to run the fans either from the unit itself or another source, the only thing from the AIO that needs to be connected is the USB connector and 3 pin for the pump onto the CPU header or pump header on the motherboard, the sata and extra connections on the AIO are all for powering the PWM fans.
As for the T-Sensor on the motherboard that is an additional addon that needs to be purchased, any 10K thermistor will work on the Asus boards.
