I want to start to custom watercool my PC, I have an NZXT s340 and i just want to do a CPU loop for future expandability. Can you link the parts I should buy?
(Im not going for the EK predator 240 or the EK starter kit because i think they are overpriced and I actually ordered a predator 240 but it arrived defective :( )
https://linustechtips.com/topic/511046-custom-built-watercooling/
I would recommend to change the case if your budget allows for it the S340 unless modded isn't the best for rad space, as for just a single CPU loop try looking into the EKWB kits they are a good foundation to build on:
https://shop.ekwb.com/kits
