Yes. Replace it with the best card for your budget. 390, 390X, 980 Ti.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/510453-help-me/#findComment-6805862
Depending on what you want to upgrade yes. If you already have a GTX 960 which is a PCI-e GPU then you can upgrade all the way to a titan (if you had the money to xD)
If you want to upgrade the CPU. Just make sure your upgrade/replacement CPU is the same socket type as your existing one. (LGA 1150/1155/1151, AMD)
PSU's can be a little dicey in big box brands but usually there is no problem.
The only thing we have to fear is... Stupidity...
https://linustechtips.com/topic/510453-help-me/#findComment-6805925
