Hi i built my first pc like 1 month ago. And i got the Gigabyte 980 ti gpu and i'm having some problems with it. For example i used to have 300+fps on counter strike  like 2 weeks ago but now its only 230 ish on dust 2. And i get alot of frame drops on Gta v, in grassy areas i get like 30-40 fps and sometimes in the city too. Sometimes it kinda locks to 30 fps for like 10 secs. Just random fps problems and mostly when its around 70 degrees i don't really know. Also when i turn off ¨ignore suggested limits¨ it says that i'm using more video memory than i should and can result in stability issues and stuff, but i'm only using 3300MB/6100MB.
I'm playing on 1080p and i have high grass quality and some very highs and distance scaling half etc.
And i have all the latest drivers
heres my specs:
gigabyte 980 ti
i5 6600k 3.5ghz
corsair 16gb 2666mhz ddr4
Please help :/
Main: Gigabyte G1 980Ti, i5 6600k, MSI Z170A M5, 16GB DDR4 2666, NZXT H440, NZXT x61, EVGA 750W G2, Windows 10
Second PC: EVGA Reference GTX 680, i7 2700k, 16GB DDR3, Corsair 300R, Corsair CX500W, Windows 10
Laptop: Acer Aspire 5750G, GT540M, i7 2630QM, 6GB DDR3, Windows 7
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/
That's strange. I have a 970 and im getting around 300fps. CSGO is a CPU dependant game it legit doesn't give a fuck about your GPU, Are you using VGA to hook it up to your monitor or something ?
"Audiophilia... when you start to hear voices in your head."
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805752
That's strange. I have a 970 and im getting around 300fps. CSGO is a CPU dependant game it legit doesn't give a fuck about your GPU, Are you using VGA to hook it up to your monitor or somethingI d
I dont know if its VGA. What is wrong with VGA?
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805771
Rma it
Whats that and how can i do do it?
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805795
VGA signal tends to degrade easily. TBH I don't think it has anything to do with that.
Im using VGA and DVI
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805802
You have a 980ti and don't what a rma is....
RMA if it is within the return period of the store you bought it from take it back and replace it if not contact the manufacturer I.E. Gigabyte and they will give you a shipping label and you ship it ff to them and they send you a replacement
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805817
Do you have two monitors ? Why are you using two ?
I have Asus VN247H. Dunno two cables came with it so...
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805833
Ah ok i get it. Its only online i think so theres no store. But when i look for warranty stuff on Gigabytes website it says that i will have to contact where i bought it from. I live in Sweden
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805843
Try taking out that vga, I have a strange feeling that's what causing it
I just tried Gta v with DVI only. Same frame drops in grassy areas.... 51 fps average fps lol...
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805882
And still around 170-240 fps on dust 2............ Theres definitely something wrong with my gpu
https://linustechtips.com/topic/510443-gigabyte-980-ti-problems/#findComment-6805929
