Right click and select delete volume to both partitions. Once that is done right click on the disk and select new simple volume and format it to the system you want.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/510317-reformatting-hard-drive/#findComment-6804366
You cannot format a drive while it is mounted.
You have to use a bootable OS such as GParted. http://gparted.sourceforge.net/
what do you mean mounted? I reinstalled OS to a new ssd and I'm just trying to use the old HDD for mass storage and free up 400gb
https://linustechtips.com/topic/510317-reformatting-hard-drive/#findComment-6804379
By mounted I mean the drive is currently being used.
yes you can.
i have done it 20 or more times
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/510317-reformatting-hard-drive/#findComment-6804450
yes you can.
Your telling me, that you have re-formatted a drive while it is being written to?
Well, that is stupid.
Also, I will NEVER acknowledge information or tips from you now that you recommend doing this.
You should ALWAYS unmount a drive before formatting it.
https://linustechtips.com/topic/510317-reformatting-hard-drive/#findComment-6804486
